Really Need You Help With Rear Differential
Guest
Posts: n/a
I am really in a pinch here and not sure what to do.
My truck vibrates very bad, makes clunk and knocking noises.
I checked all ball joints, u joints, u joints on both drive shafts, everything looks good.
Mechanic says the Main Bearing Pin in the rear differential is worn and causing this behavior.
They suggest replacing the entire rear end and priced parts to be 700 for all used parts and around 450 for labor.
Anyone know if there is a better solution for this?
Thanks everyone. I really appreciate it!
I used to have a Dodge and one day the screw that holds the crosspin in just sheared in half. It made a hell of a racket because the crosspin kept slamming around into everything. $19 and 45 minutes later, problem solved. I'm not saying this is your problem, but it is a possibility. If there is nothing else worn, there is no reason to replace the whole rearend.
Guest
Posts: n/a
Well I learned my lesson. Just have to wait and let someone that I trust give me their opinion.
That mechanic at Walk's Service center just saw an opportunity to make some money. It wasn't the main bearing pin. I suggested several times to replace the u joint. He said that wasn't it.
So the dealership was able to squeeze me in and yep, was the u joint. My friend that works there just laughed and enjoyed reading the diagnosis report that the other idiots made.
Came home, replaced both to be safe. Rides smooth as glass.
