3.55 vs 3.73
3.55 vs 3.73
Hi, i am buying a used F150. I am deciding whether I should get a 3.55 or 3.73 limited slip axle. I know the 3.55 should get better highway gas mileage and the 3.73 should have more power. Does anyone else have some more insight into this decision. Also does anyone know of either ratio being more or less dependable or having issues than the other. Thanks. Also where can I look on a truck to see what axle ratio it has (is there a sticker or something in a specific spot). THanks for any help and insight - James
Which engine and trans, and what do you expect from the truck? If you are going to be towing, get the 3.73's. I don't tow, and even with the V6 and a stick shift the 3.55's are fine - and actually I'd prefer 3.08's to get better highway gas mileage. I can second gear start without slipping the clutch.
My old truck was a 99' F-150 5.4L 2wd SuperCab with 3.55 LS rear axle and it would average about 18-19mpg, my new truck is a 2007 F-150 5.4L 4x4 SuperCrew with 3.73 LS axles and it averages anou 12-14mpg. The 3.55's are a much better choice for hwy driving, but the 3.73's are better for towing/hauling.
Off hand, I would say if you drive around town more than the highway, get the 3:73's. I would get the LS in either situation. If you drive more on the highway, you might get a little bit better gas mileage with the 3:55's. As stated above, you really wont notice the difference enough to sacrifice the drivability around town. You will have more fun with the 3:73's. If you pull/haul anything, get the 3:73's.
Originally Posted by glc
If you are buying a used truck, I wouldn't let the axle ratio influence your decision as much as I would the condition of the rest of the truck. Either ratio will be fine with a 5.4 unless you are trying to get every bit of acceleration and towing power you can get.
