rebuilding the rear end right now
First all I am doing is replacing bearings. Got the pinion out and found that the passanger side race and bearing were bad (bearing pitted race had melted in 1 place). Question is driver side carrier shim looks as if it has had the race wear a grove in it. there is a total diffrence of .0007 between the metal lost of the shim and the metal lost of the race. Since I am not going to replace ring and pinion I was going to just replce that shim to put the drive side back to factory specs. How does this sound.
