correct on the fluid and it takes just under 3 qts if you have the 9.75, and about 2.5 qts if you have the 8.8, if you have the LS than you will need to add about 6-8 oz of friction mod.
What engine do you have? If it's a 5.4, then you have the 9.75 which also has 12 bolts on the cover. If it's the 4.6 or 4.2 then it's the 8.8 and it will have a 10 bolt cover.
