Rear Diff.
Rear Diff.
So I've been reading thread after thread about the rear differential replacement/sealing/fluid/etc etc etc.. and I've decided that mine needs to come off and resealed and filled, etc...
First off, thanks to pretty much everyone who has contributed to a thread regarding the differential.
I've decided to go with Black RTV and I the recommended 75W140 Synthetic Gear Lube... at $10/liter (and I need 3 ofcourse..)
My questions are..
1.) Do I NEED the synthetic? I do a lot of highway traveling and I never really off road (or plan to..) and really only use 4 wheel drive during the winter, truth be told. I will be towing a small boat (13 footer..) but thats about it.. I was hoping to save a few bucks on the gear lube. Im not cheap, but money is money!
and..
2.) Does anyone recommend the Blue RTV over the Black, or vice versa, and why? What about the red?
Thanks!
My questions are..
and..
Thanks!
75W140 Synthetic is what your truck requires. You will also need the Friction Modifier from Ford. The Motorcraft 75W140 is about $27 a qaurt from your dealer, and the Modifier around $10. I love the black RTV when sealing anything from water pumps to diff covers.
Just remember to clean the surfaces with a razor blade than wipe the mating sufaces with brake cleaner to ensure a good seal.
i used orange rtv on the 9" under the 77 F150 4x4 between the carrier housing and the axle housing when i swapped another carrier housing on last fall
has been fine
i hear the 4x4 guys use ordinary white caulk on rear ends to seal them
and you could always get the gasket from napa or dealer btw
good luck
has been fine
good luck
*cough* Walmart *cough* has 1QT Bottles of SuperTech (Their own brand..) 75W140, says Synthetic... for $10 a bottle.. I saw it as too good to be true.. it doesnt say blend or anything, just synthetic.. thats why I was kinda hopin to use that instead.. but I figured I would ask. If it works fine I'll use it!
