What Gears for 35" tires
Actually 4.10 would be almost exactly the same final drive ratio as stock if you had 3.73 gears to begin with.
The formula is like this; New tire diameter / old tire diameter x old (or current) axle ratio = new axle ratio
That formula will simply tell you what gears you need to get the same final drive ratio you had. since you have the 4.6 I'd suggest going a size more for the extra power (i.e. 4.56)
How can I find out what my stock gears are , read the label inside of door ?
Old tires p255/65R17 new is 35+12+5
The oweners manual says 3.55 GCWR 4536 or 3.73 GCWR 4763
even stock it was a little bit of a god on big hills so I woulden't mint stepin it up a notch , I do a lot of freeway driving
Originally Posted by clar
talked to the local gear shop and they said 4.56 gears and $827.00 need to find some one cheaper this truck only has 10k millage so it does not need bearing work , need shop in San Diego
