Will this gasket stuff work for my differential?
![Thumbs up](https://www.f150online.com/forums/images/icons/icon14.gif)
Originally Posted by Quintin
The black Permatex stuff works just fine, that's what I use. The most important thing is to be sure both the cover and the housing are as clean and as dry as possible, and to not get carried away with that stuff. A little goes a long way.
![](http://www.imagestation.com/picture/sraid225/pf8bb0893345a4c6b71cbde91631bb61f/e8eb65ba.jpg)
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
on
Originally Posted by syoung_2000
would you guys recommend buying a new cover from the dealership if mine is flaking kinda thick pieces of rust?
If you are worried about it and have a 8.8 you could nab a finned cast aluminum cover off of an Explorer at a junkyard. No rust, runs cooler and is probably stronger if it would take a hit from something.
If you have a 9.75 unless the Expeditions did the same thing you are SOL and stuck with the stock steel one.
![banana](https://www.f150online.com/forums/images/smilies/banana.gif)
