electrical gremlins??????
ive got a 99 f-150, 5.4,2wd,and i received 2.5 in of rain yesterday. since then my blower fan runs without key in ignition and headlights flash. it flashes a code 16 on the theft light and will not start until i take the battery loose for abit, and manually lock the doors. there is a solenoid clicking uncontrollably under the dash. my a/c and cruise are not working as well. i tested the #5 relay and it works on testbench. is my GEM bad or is it the computer?.....please help!!!!!!!!
re gremlins
ignition switch is fine...truck was bought used from a friend. this is an acute problem...one minute ok and next major problems. called dealership and they said they had not heard of this before......????? the gas gauge,voltmeter and odometer stay on constantly w/o key. headlights flash uncontrolably when auto lights are on w/o key.....thanks for the help people
re gremlins
Is it the Solenoid on the firewall or something under the dash? If it is the Solenoid on the Firewall you got an ignition sort.
However it sounds like you got a short somewhere. Could be in the steering column, Ignition wiring harness, maybe at the switch or around the bottom of the steering column where the wiring harness come out of the steering column?
Anyway good luck. I have had experience with Tommy Knockers (Gremlins) my self. Not fun.
