Trying to figure out a noise PLEASE HELP
ok so i thought at first my serpetine belt was bad but now im starting to wonder. there is a slipping noise when driving down the road at a constant speed and then pushing slightly more on the gas at certain speeds the noise is also constant while holding the gas constant. if i push the clutch in and give it gas it doesnt make the noise im stumped what it might be any help trying to figure it out would be great
thanks in advance
david
thanks in advance
david
well i had my wife set in the back of the truck while i circled in a parking lot the noise is from the driveshaft. when i got home i jacked it up and put the truck in neutral when i turn the driveshaft by hand i can make it make the noise sounds like it is coming from the driveshaft itself but im sure it is probably amplifying some other noise. truck only has 66000 miles on it doesnt feel like it needs a clutch still got a lot of pedal left. let me know what you think. thanks again
david
david
