ABS Question
ABS Question
I have a 2001 super crew 4wd that has 2 issues, maybe related. 1st is that when I am coming to a stop sign or slow braking, my ABS activates causing brakes to slip some. 2nd problem is that sometimes when going around a corner, it sounds like my wheels are locking up or skipping, kinda what it sounds like when 4wd on dry pavement.
Garage said they had no idea until they went through a diagnostic for $75.
Any help would be appreciated.
Steve
thehathaways@unicorncomputer.com
Steve
The first problem is most likely caused by a bad ABS sensor, probably the one on the rear differential. They are known to go bad, and most Ford dealerships will keep them stockpiled in the back. My truck had the same problem, I replaced the sensor and problem solved. If it gets to the point where it's not safe to drive, you can always take out the ABS fuse temporarily.
The sensor is around $23 and is held in by one 10mm screw. Should take around 2 minutes to replace.
Could the second issue be related and is sounds like it is coming from the rear?
Originally Posted by thehathaways
Great, thank you, I think I probably handle this fix. I will try it and let you know.
