transfer case switch
I currently have a A4WD, 4WD hi, and 4WD lo transfer case and i want to look into having a different transfer case that incorporates 2WD to those other 3 drive settings. Is this something ford could do easily or wold it be a big expensive project? Would it help with gas mileage?
on
You will at the very least need a new T-case with shift motor and switch. The GEM might need to be replaced too. The GEM is what shifts the motor not the switch. As there is an extra position on the switch for 2WD and your GEM might not recognize the extra position. Your front Differential doesn't have the shift collar that disengages the front axle so any economy that you are thinking of obtaining by being in 2WD will not be that much.
JMC
PS. If you still want to do it let me know and I will look up more info. This is all off the top of my head.
JMC
Originally Posted by FlowinExpo08
the main goal would to try and get better economy because i dont need the AWD system all the time and i was hoping that the 2wd transfer case would gain me a couple mpg.
Overall, by modding your stock truck, it will probably be unrealistic to recoup the costs.
on
...i dont need the AWD system all the time and i was hoping that the 2wd transfer case would gain me a couple mpg.
the main goal would to try and get better economy...
on
In 97-98 MY Expeditions Ford uses a 4 position T-Case. 2WD, A4WD, 4WD HIGH and 4WD Lo. You could try to fit one of those to your truck. They used a 4 position switch so you will need that too. The big question is weather the GEM will recognize the 2WD position. The switch uses different resistance values to tell the GEM what position the switch is in. You will still be spinning the front driveshaft in 2WD because you don't have the center axle disconnect system.
JMC
JMC
