Differential speed sensor ring
Old 09-03-2007 | 10:38 PM
pazzo's Avatar
I'm going to replace my diff. carrier but I was told that I cannot reuse the anti lock speed sensor ring. I can't find one on the internet. Is this a dealer item only?
Old 09-04-2007 | 01:35 AM
Steve83's Avatar
Ford doesn't recommend reusing them, but I have. If you can't get it from NAPA, then it's dealer-only. Have you checked the online dealers? I'm sure some of the vendors here are authorized, but the ones I know of are:
http://www.teamfordparts.com/partloc...?siteid=214270
http://www.1stfordparts.com/
http://www.drivetrain.com/ford8.8.html
http://www.rockauto.com/
Old 09-04-2007 | 08:21 AM
pazzo's Avatar
Yeah, I've been looking on-line for several days, including the links that you sent. Can't find anything. Must be dealer only.
Old 09-04-2007 | 08:46 AM
jiggle's Avatar
I've reused mine through two rebuilds with no problems to date.
Old 09-04-2007 | 02:52 PM
pazzo's Avatar
Thanks, I guess I'll try to reuse mine and see what happens.
Old 09-04-2007 | 09:37 PM
jiggle's Avatar
If you're really worried about it just buy a new one. I can't cost all that much, although it is probably special order. IIRC, to change that thing out would mean that the whole rearend would have to be setup again, because the ring gear has to be removed to get to it. I could be wrong though. It may be worth it just to go ahead and replace it.
Old 09-05-2007 | 07:46 PM
2002 wonderboy's Avatar
Hey there Pazzo. I put a truetrac in to replace my open diff, and i reused the speedo sense ring. Yes it does go behind the ring gear. I have'nt had any kind of problems with mine.
I've never heard that you cant re-use the thing. Maybee if it was missing the pickup teeth or warped that would be a dead giveaway to purchase a new one. or if you damage it somehow on the rebuild
Hope this helps you out.
Old 09-06-2007 | 02:03 AM
Steve83's Avatar
Originally Posted by jiggle
...the whole rearend would have to be setup again, because the ring gear has to be removed to get to it. I could be wrong though.
Yep. You're wrong.
The tone ring can be removed/installed without messing with the ring gear, and even though the carrier has to come out of the axle, you don't have to reset the gear mesh since you're putting the same gears back with the same shims.
Old 09-06-2007 | 02:15 AM
jiggle's Avatar
Originally Posted by Steve83
Yep. You're wrong.
Can you explain how you remove the ABS gear without touching the ring gear? It's been almost a year since I had mine taken apart, but I thought the ABS gear went between the ring gear and the flange on the carrier that the ring gear bolts to. Perhaps you have a diagram?
Old 02-09-2012 | 04:25 AM
hillbillymidget's Avatar
Question need help with my 1994 ford f150
i can't figure out why my speedometer doesn't work, i have changed the speed sensor and i have changed the speedometer cluster and it still doesn't work. would i work if i reseted the speedometer cluster? not sure what else to do with it. let me know what else i can check or do.
Old 02-09-2012 | 11:39 AM
sam1947's Avatar
Yep. You're wrong.
... Maybe a different rear end..my 07 has the ABS ring sandwiched between the ring gear and the carrier. (3.73 w/tru-trac)
Old 02-09-2012 | 11:47 AM
sam1947's Avatar
TascaParts.com has them listed
Old 02-09-2012 | 01:55 PM
Sam, please check the posting dates...........
Hillbilly, please post in the pre-97 forum instead of bringing up a 5 year old thread that doesn't apply to a 1994.
Old 02-09-2012 | 08:40 PM
sam1947's Avatar
Can't believe I got caught with this again !! :o I HAVE to get these glasses changed !!!
Quick Reply: Differential speed sensor ring
