Gear swap????
Gear swap????
okay, I have a 2000 F150 2wd w/ 5.4 and 20" wheels with 285/55's. I pull an enclosed trailer around but I also go to work an hour each way on the interstate empty. On occasions I will pull my trailer on the interstate. I currently have 3:55's, would swapping to 3:73's give me a little more power as well as better mpg?
I think the consensus is that for a gear change to be worth it you should move up atleast two ratios, so atleast 4.10 gears. With 33s I would go with 4.30s or even 4.56. You wont neccessarily get worse gas milage either. I went from 3.55 to 4.56 with 35s and I actually get better gas milage because of the decrease in engine load.
Originally Posted by jiggle
I would go with 4.10s unless you plan on going up in tire size again.
But it sounds like you do a lot of highway miles with no trailer, so 4.10s would be good.
Don't waste your time with 3.73. It's not enought of a change for you to notice and benefit versus the cost involved.
