Do i add friction mod to both axles?
Getting ready to change the gear lube in the differentials. Book says to add friction mod to the rear axle. (yeah I know pretty easy) Question is does it also need to be added to the front axle if four wheel drive? I thought it would only be in the rear for the LS but the book did not mention that. So does it go in both or just one?
And - if you use certain brands of rear diff fluid, you don't need to add the stuff, as it's already incorporated (e.g Royal Purple 75w-140 synthetic)
thanks. That's what I thought. Just making sure.
So Royal Purple is order online only or available locally?
Check RP's web site for the Dealer locator tool.
bubba
BTW - off-topic - PI is selling the I/C 5psi RouchCharger for $7,199
