changing the axle seal
Pull the cover off the rearend and let the fluid drain. Remove the small bolt that hold in the crosspin. Loosen the tire lugs and jack the rearend up so the tires are off the ground. Hold one tire in place and have somebody rotate the other one until you can pull the crosspin out. Remove the tires completely. Remove the brake calipers and the caliper brackets. Push in on the axleshaft (toward the differential) and the c-clips holding them in should fall out, or you may have to give them a little help. After the c-clip is out the axle can be pulled all the way out. I've never replaced an axle seal, but I'd imagine that's probably the easiest part of all this. I think you just pry the old one out of the tubing and carefully push a new one in. Somebody else will have to clarify. Reassembly is just the reverse of all this.
I'm trying to remember how to do all this off the top of my head, so if I forgot anything somebody please tell me.
Drum brakes, all you have to do is take the drum off. It'll just pull off as long as you don't have the parking brake set.. Well, it could still have a retaining clip on one of the lugs, so just pry it off. It could also be a little 'stuck' to the hub, so a few bangs with a rubber mallet should loosen it up...
Another thing is to make sure you replace both seals even if only one is leaking... Since you got the whole thing apart anyway, doing one more axle is not that much more work.. Well, it does take an extra beer or two as well!
Get the correct gear lube as well... Yours should call for 75w140 as mine did. Either get the Motorcraft stuff and add the friction modifier or go with a name brand.. I used Royal Purple this last time and it's spec'd for LS without the need to add any additional fm..
You will also need to get some RVT gasket stuff for the cover.. If you have the 8.8 rear, you might be able to find an actual gasket, but I've had good luck with only the RVT stuff for my 9.75.
Mitch
Mitch
