Rear Driveshaft coming out?
Rear Driveshaft coming out? PICS UPDATED
I was under the truck today and noticed that the driveshaft going into the transfer case looks like its coming out. I took pics to show, but dont know if anyone else with a lifted truck might have this problem. Please help?
I have a combined 8 inch lift, a 6 inch pro comp with 2 inch bilsteins up front and the 5 inch block with a aal. I didn't know if it was dangerous. you don't think it will be a problem, I don't do any off roading, its a street truck. I don't want the driveshaft coming out and causing a wreck.
does it all the time between 45-60 and shakes it pretty bad but it shakes the front also. I think I need to get my tires and rims road force balanced. I took the truck to a mechanic and he got me over worried that this driveshaft was going to fall and flip the truck. I think I just got over parenoid. feel a lot better knowing its a little better than the mechanic said.
Hey how do the bilsteins feel up front. I have that lift and I wanna do the same thing you did. Did you crank them all the way cause your angles dont look bad. Is there room for 37's
hey hash, the preload on the bilsteins are maxed at 2 inches, I dont know if I can fit 37's. The ride with the bilsteins are great. If your gonna go with the bilsteins tho, get the bilsteins that you can adjust from 4-6 and get a leveling spacer. Having the basic pro comp lift and seeing that big spacer really sucks. I keep thinking the samething, I dont want to buy the 37's to find they rub bad, but theres alot of room in the wheel well to fit some tire. Its all about being able to turn the wheel though.
