how do i tell what gear ratio i have
Searching "axle codes" returned about a million posts, more or less. Try this one
https://www.f150online.com/forums/sh...ght=axle+codes
on
Originally Posted by glc
If you can turn it easily and the driveshaft rotates, you don't have limited slip.
Originally Posted by Steve83
The first digit tells the chassis weight & type of diff; the 2nd tells the ratio; if there's a 3rd digit (4WD only), it means the front diff is limited slip. In the first digit, 1 is the code for most 1/2-ton open diffs; 2 can be 1/2- or 3/4-ton open; H is a 1/2-ton limited slip. (Any letter in the first digit means L/S.) In the 2nd digit, 2 = 2.73; 3 = 5.13; 4 = 3.54; 5 = 4.10; 6 = 3.73; 7 = 3.31; 8 = 3.08 (or sometimes 4.88); 9 = 3.55.
