noob here...with another changing serpentine belt?
Old 10-23-2007, 09:13 AM
blk05coupe's Avatar
I’m replacing the serpentine belt in my 2000 f150, what size is the square driver I need to spring the tensioner i tried a 3/8 and it's to big and a 1/4 is to small.
thanks
Old 10-23-2007, 09:28 AM
2002 wonderboy's Avatar
Try the 3/8" again. Pretty sure thats what size it is. maybee your driver was'nt squared up with the hole, and if you use a ratchet, be sure the ball detent on the ratchet goes in.
Old 10-23-2007, 12:32 PM
jiggle's Avatar
It's actually a 1/2 inch drive. I don't know why your 3/8 didn't fit. And you'll probably need a breaker bar or a huge ratchet. You have to put a lot of force on it, and a regular ratchet just won't give you the leverage.
Old 10-23-2007, 12:36 PM
blk05coupe's Avatar
movement is not the issue i'm not able to get a 3/8 drive ratchet into it.
Old 10-23-2007, 12:47 PM
jiggle's Avatar
Maybe there's something stuck in it then because it's definitely a 1/2" drive.
And all I was saying is that you'll need a cheater bar or something to help you get leverage once you do get a ratchet in there.
Old 10-23-2007, 12:54 PM
jiggle's Avatar
Old 10-23-2007, 01:03 PM
blk05coupe's Avatar
thanks
i wonder if the 2000 4.6 is different or if something is stuck in it, i bought it used a few years ago.
Old 10-23-2007, 01:13 PM
jiggle's Avatar
All three engines should be the same. I have a 2002 4.6L and that's how mine worked.
Are you shure you're putting the ratchet into the correct spot?
Old 10-23-2007, 01:22 PM
MGDfan's Avatar
Precisely. OP - I had the exact same truck - I used a long 1/2" breaker bar.
Who knows, though, right?
Pics, maybe - with a 1/2" short extension adjacent to the hole you are using for comparison?
Old 10-23-2007, 01:24 PM
blk05coupe's Avatar
Not sure…I assume it would be at the spring portion not at the actual pulley…but I could be wrong.
Old 10-23-2007, 05:59 PM
jiggle's Avatar
I think it actually is at the pulley. It's been a while though so don't take my word for it.
Old 10-24-2007, 06:37 AM
blk05coupe's Avatar
yup....you are correct, i'm all set thanks for your help.
Quick Reply: noob here...with another changing serpentine belt?
