cable operated locker for 8.8"?
has anyone heard of OX lockers? is one available for our trucks?
i need open diffs for wet highways yet would like the peace of mind of a locker to get rolling now and then. the LS is still too much for new england roads unless i haul a payload at all times.
The true trac is NOT a locker. It IS a limited slip (clutchless) and will not wear down and will hold up for a long time, however it does NOT give you the same traction as a locker. The OP also says he doesn't want it to be LS all the time, he would like an open diff sometimes (I don't know why... but to each their own). I would HIGHLY recommend OX lockers. They are a great, STOUT locker and come with a cable instead of the stupid air line (which get ripped right off in heavy duty off-roading) or the stupidest thing I have ever seen an electric locker ( i have eye witnessed 3 failing during water crossing/mud boging). The cable locker is great, plus it comes with its own OX locker brand heavy duty dif cover. But if you don't do any hard core offroading (and with ifs... i doubt it) i would thinkin about ARB air lockers. Get the air locker, its selectable. plus you get an on board air compressor which can be used for filling up tires/rafts/airbeds and pneaumatic tools!!! Just a thought...
An ARB can possibly be setup for the same price as an OX and I would prefer to ARB because of the air capability. Run your air lines right and you should not have any problems with them getting ripped. I know quite a few people who run ARB's and don't have problems with lines rather rock crawling or mud bogging.
