4.10 Gears
Old 09-06-1999 | 11:21 AM
conqsoft's Avatar
Post 4.10 Gears
I'm thinking about going from 3.55 LS to 4.10 LS. Any concerns I should be aware of? Also, what kind of cost am I looking at? I assume it has to be changed for front and back since mine's a 4x4....
Thanks for any info.
keith@myf150.com
http://www.myf150.com
Rocky Mount, NC
1999 F-150 XLT Styleside, Black On Black, SuperCab, Short Bed, 4x4, ORP, 4.6L Auto, 3.55LS
Mods: DrawTite Class III Hitch, Smittybilt Outland Grill Guard/Brush Guards, KC Daylighters, Custom Dual Exhaust-Straight Out The Back, Airaid FIPK, SuperChips Chip, Bug Deflector, Pace-Edwards Roll-Top Bed Cover
Old 09-06-1999 | 11:36 AM
T Ellenberger's Avatar
Post
Yes, if you want to use 4 X 4 you will have to change both.. The only concern is you will turn more rpm's to go the same speed as with the 3.55. This will result in a little less mpg's. But, who cares, look at the performance feel you will get. The pull off the line should be terrific.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old 09-06-1999 | 12:19 PM
StrangeRanger's Avatar
Post
You're looking at about $300 per axle in parts, $2-300 for a shop to set up the rear and a bit more to set up the front. You'll probably be very surprised at how little mileage you actually lose and how much performance you gain.
Good luck
Old 09-06-1999 | 12:25 PM
conqsoft's Avatar
Post
Thanks for the info. So I'm looking at around $1200 +/-...
keith@myf150.com
Rocky Mount, NC
Old 09-06-1999 | 02:51 PM
veloci's Avatar
Question
strengeranger, ellenberger
i have a question for you guys since you seem to have experience when it comes to gears. I just installed 275/70/16 on my 2WD truck and of course i lost some rpm's sort of speak. I am thinking about installing 3.73 gears. do you guys think i will pickup some of my guts back and are there any drawbacks to this change? also, should i go 4.10? thank you for any help you can give me.
99 xlt sc,4.6 2w.d.,gibson catback,superchip,airaid,rsx shocks,hellwig sway bar(soon to be removed),3" front lift.
Old 09-06-1999 | 10:49 PM
dogcam's Avatar
Post
How's it going conqsoft? I am sure glad you got that "Make my JOB better", you're out putting more $ $ in to F150, I need some "goodies" too, send me some of that $$............Take Care
dogcam@myf150.com
97 Lariat s/c 4x2 5.4
all mods off, turning it
in for a new 00
Dogcam
dog46cam@webtv.net
Old 09-06-1999 | 11:00 PM
conqsoft's Avatar
Post
Well, gotta spend it on something.
My local Ford dealer wants $450 per axle just for parts. I laughed.
Anyway, I'll check around for better prices.
keith@myf150.com
Rocky Mount, NC
Old 09-06-1999 | 11:59 PM
Squanto804's Avatar
Post
Boy, the quotes you all have gotten seem really high. I bought my gears from 4Wheel Parts Wholesalers for $150 per gear(plus $70 for bearings and shims per axle} and had a local shop put them in. $160 for the rear and I removed the front axle myself and took it to them. Saved some money but is easy to do. It cost $120 for it. I did'nt think it was a bad deal for $720.
97 F-150 Black, 4x4 XLT ext.cab,sb,offroad pack.
4" Susp. lift, 3" body
4.56 gears w/LS,Borla exhaust
35" BFG.,16.5x9.75 Weld Scorpio V wheels, Edelbrock IAS Shocks,Lift Lips,
K&N Filter, TransGo Shift kit,
Bug shield,Tinted windows
Sony ES head unit,Sony ES changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://hometown.aol.com/squanto804/scottwebpage.html
Old 09-07-1999 | 12:08 AM
Post
veloci
Your tires are about 3.8% larger if you started w/255/70s or about 7.4% if you started w/ 235/70s. To get back to where you started you'd need either:
3.55 x 1.038 = 3.68 gears
or
3.55 x 1.074 = 3.81
the closest available ratio to these would be 3.73 which is 5.1%. Basically, a change that small in ratio isn't worth the time, money or effort it would take. Either drive it as is or go for the 4.10s (15.5%) to get a real gain in performance for the same bucks.
Old 09-07-1999 | 12:14 AM
conqsoft's Avatar
Post
Squanto,
What brand gears did you order from there? I was looking at their site and they have several.
Thanks.
keith@myf150.com
Rocky Mount, NC
Old 09-07-1999 | 12:38 AM
veloci's Avatar
Talking
strangeranger,
thank you for the info. I think i will go for the 4.10's. i will let you know how it turns out.
Old 09-07-1999 | 12:59 AM
Squanto804's Avatar
Post
conqsoft, they were "Genuine Gear", from 4 Wheel Parts Wholesalers. I actually first called Drivetrain Warehouse and that number goes to 4wheelParts Wholesalers, which was fine with me. I think they go for about $165-170 but I just asked them for there best deal and I got them for $149. Not a bad deal! I did purchase my lifts, wheels and shocks from them but they did not know that when I called. I just said "I had ordered from them often". They have always had good service, so no hesitation from ordering them.
Check it out at:
http://members.aol.com/squanto804/scottwebpage.html
[This message has been edited by Squanto804 (edited 09-07-1999).]
Old 09-07-1999 | 10:27 AM
dogcam's Avatar
Post
Conqsoft, man you keep forgetting you live in NC, "the land of High prices".
When you get your gears (at a good price) why not use the place where you had your Pace Edwards installed? Can't think of their name?/this happens to me alot..
I thought they were a pretty good size shop, that could work on any type truck.........
dogcam@myf150.com
in for a new 00
Dogcam
dog46cam@webtv.net
Old 09-07-1999 | 10:51 AM
conqsoft's Avatar
Post
I installed the Pace-Edwards myself.
I WON'T be doing that with the gears, however.
keith@myf150.com
Rocky Mount, NC
Old 09-08-1999 | 12:57 AM
Neal's Avatar
Cool
HI!.. The dealer I bought the truck from did the installation. Total price after buying - 4oz. friction modifier, PRECISION GEARS 4.10 (ring + pinion), tube of silicone (for inspection cover), pinion nut, cruch collar, and 4 1L bottles of REDLINE synthetic rearend oil was just under $1000.00(CAN). It only took them 4 hours to do the installation. WOW what a difference. As soon as I picked up my truck I drove it around a little to make sure everything was working fine. Then the test. I drove out to the local "street" dragstrip and made a few runs. Before I use to hit about 89mph in the 1/4 mile, but now I hit 94mph. Not bad, 5mph increase. The truck is much more responsive than before and you barely have to touch the gas pedal and your off, FAST! I lost roughly about 8 kph in each gear compared to the 3.55's, but it is hardly noticable. I can say one thing for sure, and that is that the top speed limiter comes very quickly now. The next thing I have to do is to send my computer into SUPERCHIPS to get the "no start" problem fixed and then I'll be all set for the MILAN meet.
Quick Reply: 4.10 Gears
