Axle tag decoding
Axle tag decoding
Here is the info I have from each tag, I know the rear axle assembly was swapped if I read this right it is the wrong gear ratio.
REAR TAG
S 854B
3 31 88 8K26
FT. TAG
S - 956A
3 55 88 6B09
My truck is factory 3.55 and I assume the rear tag shows a 3.31 not good for 4X4.
Thanks!
Mike
REAR TAG
S 854B
3 31 88 8K26
FT. TAG
S - 956A
3 55 88 6B09
Thanks!
Mike
like the previous posts said, i would'nt be puttin her in 4wd either
hopefully the people that done this accidentally put a wrong tag on your cover. i would be prying the case apart myself, counting the #of ring gear teeth/ #of pinion gear teeth= gear ratio, or do the wheel spin thing by counting the number of times the driveshaft turns vs. one complete turn of the rear wheel.
when i changed my gears out, i just removed the tags, and used a paint marker to identify the gear ratio on the rear /front axle. yeah, thats a pretty raw deal if those gears are actually different!
Well I am pretty sure the tags are correct. I drove it out in my backyard and tried it out this evening everything shifts fine but when I pulled back on the drive way in the rain it was spinning the rear tires aginst the ft ones, so 2wd it is until I can change the rear back to 3.55. STINKS!! The guy I bought this truck from was a idiot... just keep finding things to fix.
