Grindin my gears
Grindin my gears
ok i currently have a 97 standard cab flareside f150 with 4.6 and automatic n 4wd looking into a big suspension lift about 10" sometime soon....am currently running stock open rearend with 3.55s and 265/75/16 mud tires and was thinking about 4.88s and l/s with the lift and 38" tires...but would that just keep me at about the same ratio as i am now? i am lookin to put some ore umphh into the truck if im going to spend all this money on gears.....so i also thought about maybe 5.14s would that help out in the power department? also one last question what if i just put the gears in now without the lift and big tires would fuel mileage plummit with the closer gears but my truck be strong off the line or would fuel mileage not be affected too much?
thanks in advance
thanks in advance
Lift, Bigger tires, higher gears = less mileage.
The larger tires are heavier and would require different gears just to turn them more efficiently. = less gas mileage
The lift will increase wind resistance + add weight = less mileage
The gears will have enough strength to handle the tires but you run higher rpm's and lose top end speed which = less mileage.
Neither of the things you wish to do will really maintain mileage the same. Alot will depend on how you drive but they all increase the capability of your truck, not necessarily improve mileage. Go with what you will see the most out of your money. JMO
I am looking at going 4.88. In some places I found cheaper than the 4.56(although this is probably the most common and widely available) I am not expecting great gas mileage but more power to turn the tires well in the mud and sand and offroading on hills and such.
Here is a place that I had seen some
http://www.jawsgear.com/store/catalo...oducts_id=1391
http://www.4wheelparts.com/PPT6066T100679.aspx
http://www.riversidegear.com/search.php
thanks for the links yea not really worried about fuel mileage since its terrible already so i figure i might as well have a bada&& truck that can actually move and looks sweet than one that has no power, looks stock, and gets bad mileage. im just looking for gears that will move my truck faster off the line not worried about top speed since ill be sittin 10" higher than i should be plus the bigger tires. if anyone knows where to find reverse cut 4.88s or higher for the 8.8 ifs let me know thanks
That sounds lika a good deal to me. most of what I was looking at for mine was 770 and up. Remember the most important will be a reputable shop to install them. I don't think gears are expensive for what they do in terms of benefit to your truck. BUT believe me when I say it sucks when they are not installed properly. It was a headache when I had some 4.10's placed on my mustang. They whined like crazy. I had them removed and I was told they were not shimmed properly. you could see the wear on them where the metal was grinding.
