Detriot Trutrac or OE LSD for boat ramps?
Originally Posted by LastSplash
The tru-trac is not as smooth as a LS, they still click on sharp turns. If you go with a LS get an Eaton LS they are alot stronger than the OE LS.
My vote goes for the TruTrac all the way! It'll out-perform any OEM limited slip with the exception of the Torsen diff in some of the Rangers. (The Torsen, Quaife, and TruTrac are all similar gear-based torque-biasing differentials) TruTracs will operate smoothly and seamlessly in all conditions. They occasionally require a bit of brake pedal modulation to engage, but once they do, they'll drive you out of a hole every time.
-Joe
From what I have heard, i disagree with that. A true trac will last the longest due to the conical gears. An Eaton Posi won't wear out as fast as a factory tracloc. The factory tracloc is built for mild use. Every bit of material i have read says that the eaton posi is one of the most aggressive positraction units on the markets, hence its pricier price tag. I'm not saying that the true trac stinks. I'm just saying that the factory LSD and an aftermarket LSD can't be compared on the same level. One is built just to get by, the other is built for a performance enthusiast.
I understand what you're saying... I may not have been clear on what I was trying to say...
Yes, The Eaton Posi is aftermarket, which generally means that it would be a better unit than the OEM TracLoc LSD. The point I failed to make clear is that it's still a clutch-based limited slip diff, meaning it has clutches, and those clutches slip and wear out much easier than any of the torque-biasing differentials out there. Once the torque difference exceeds the spec, the low traction wheel will spin until the cows come home.
Torque biasing differentials (e.g. Torsen-type limited slips) will not exceed the torque bias ratio. (i.e. they will actually limit the slip of the low-traction wheel). That's what makes a torque-biasing diff like the Torsen, Quaife, or TruTrac such a great performer: It DOES allow some slippage, which is ideal for a vehicle driven on the street. However, unlike a clutch-based LSD, it truly limits the slipping wheel's spinning.
Does that make more sense?
I had a toyota p/u that had a tru-trac and it was not as smooth as any clutch pack LS. You could hear it click and feel it when parking, although the clicking could have been the drivetrain binding and releasing.
Personally I would get either an air locker or electric locker, when you need traction push a button and the rear end is locked, push the button again and the diff is open.
You must be thinking of the Detroit EZ-locker, the EZ-locker is an upgrade from an open difff and about as strong as a OE LS.
The tru-trac is a helical gear LS no clutches thats why they click and are not as smooth as a clutch pack LS.
Here is a link there is lots of good info there.
http://www.eaton.com/EatonCom/Produc...cker/index.htm
The trutrac doesn't click or pop. The detroit locker does, and so does the ez locker and other "lunch-box lockers"
I did some research on this subject a while back and everything I found indicated that the trutrac outperforms any clutch style limited slip hands down. It's only drawback is that if you have a wheel in the air, then it acts like an open differential. (no resistance) You can get around it by giving it a little brake to provide the resistance it needs to multiply the available torque back to the wheel with grip.
