rebuilt my stock posi and left out a few parts
Well I had the annoying shudder from the rear of my 9.75 on my 05screw so I picked up a clutch rebuild kit for it off ebay for $25 and decided to save some money and do it myself.Well it all went fine except I could not get the cupped washers to slide in behind the 2 spider gears that go on the cross shaft.I spent 2 days trying and I could only get the spiders in not the washers as well.I ended up completely destroying the washers before I finally gave up and just left them out.Just curious how many problems this is going to cause for me?If it was an open diff then I would really worry since they would spin all the time but being a posi ,,In theory they won't spin all the time so they shopuldn't wear the case that bad but the life of the spiders and possibly case will be shortened.What do you all think,Am I right in my thinking or make a really bad choice?
Originally Posted by mycio4791
yea it was a bad idea if its stock its not posi its limited slip so they will spin and yes its gonna wear stuff out quick they should've went right back in u must have done somethin wrong
Originally Posted by High Profile
it's gona wear out your carrier where the cupped washers are... they will spin.
Originally Posted by LariatSCrew04
Those cupped washers are thrust washers, they act as a bearing surface between the gears and the carrier housing. Without them, the gears and housing will be scored to **** pretty quick.
yah ive built a few rear ends too. Not fun and then you get it all done and have to measure everything, then usually have to tear it back down halfway again.
yeah man gj on getting it together the 2nd time around. those thrust washers are pretty important, notice how smooth they are when u first got em out?
