how to replace sertine belt ?
Should be just like mine...
use a 1/2" drive ratchet or breaker bar and insert it into the hole for it on your tensioner pulley. This should be on the left side of the drive pulley, behind the fan shroud (either wear a long sleeved shirt, or be ready to cut your arm jamming it into the space...not a lot of room)
force the tensioner away from the belt
remove old belt making a note of it's routing (if you dont have a drawing, make one), or check out jbrew's pics for a routing diagram
route new belt just like old belt
rotate the tensioner pulley just like you did to remove the old belt.
slip the new belt on.
I am having a problem getting the tensioner to move, let me know if yours moves easier...
hope this helped
-Dan
hope this helped
-Dan
