manually shift 4wd
manually shift 4wd
i pulled my 4wd lever to put it into 4 and the lever broke off. i was wondering how i could shift it manually into 4wd underneath the truck. i cant re-attach the shifter because the bolt broke inside the nut that is welded to the bracket. so i need to get that nut off first and i dont have time. i was wondering which way to move the linkage because i need 4wd in the snow/ice that has been accumulating in the backwoods of the northeast. i have been trying to move the linkage but with no luck. the 4wd was working great before this happened. i have PBblasted the crap out of the linkage so it should move more freely now. any help would be appreciated
Move it forward for 4 hi and lube all with WD40 it works the best and don't be stingy with.. good luck.
