HELP.. oil leaking from axle end..
Originally Posted by KEITHHATTER
There are 2 tags on your rear end. One says 75w140 synthetic only and the other has the specs for the differential. If you see a LS on there you that means the obvious. You have a LS differential. You can also do a search for differential identification and it will pop up numerous posts with this info.
to be honest it wasn't hard at all (knocking on wood) i did grab a Haynes manual for $17 which tells ya step by step.! with the manual, both seals, gasket maker, LS addative, brake cleaner and 3 qts. of mobil 1 synt. fluid it cost me just under $100.... i called a few places and they wanted anywhere from $180 to $230 per side. Thanks again guys!! and hope i did it correct or i'll be stranded somewhere between here and IN......
