Cracked my front axle tube
Not sure how I did this, but it happened very recently (today or yesterday). Caught it because I was about to change my oil and saw gear oil dripping from the front end.
I'm not sure whether to replace it or to just weld it. It's cracked all the way around, so it's separated into two parts now. To remove it I assume I have to drop the whole front end, take the differential apart and remove the axle? Anybody seen anything like this before?
Well I pulled the whole front end down, took off the diff cover and pulled out the crosspin thinking that I would have to pull the C-clips to get the axle out like on the rearend. Turns out I could have just unbolted the axle tube and pulled it off. Oh well. I'm going to hit up a junkyard or two tomorrow to see if anybody has one.
Klitch, are you sure that it's $200? That seems like a lot, even for Ford. It's only a 1.5' long cast-iron tube. I can see it being a bit more if it comes with the bearings pressed in, but $200 still seems high. Hopefully I can find a used one elsewhere.
Edit: It's $142 on directfordparts so it is probably close to $200 from a dealer. Anybody know if it comes with the bearings/seal installed?
Originally Posted by torkum
Wow! If you didn't feel anything you could have had a crack for a long time that has grown to the breaking point. I would recommend a new tube because it is a pain to get the gear oil out to make a clean weld.
Oh and degreaser will get off gear oil. BTDT, lol.
Also, I'm running 4.56s. When I went to remove the crosspin, I couldn't get it out because the ring gear was too fat. I know they will normally either use a notched crosspin or grind down a tooth or two to make it fit. Neither was done on my truck. How the hell did they get the thing in there? I had to take a dremel to one of the teeth to get it out.
u sure the pin was being pushed the right way? i looked at my rear for 15 mins got mad and walked away. came back to it and shove it out the other direction.
Originally Posted by billb72249
Does this mean it's possible to replace the passenger side oil seal without removing the front cover and removing the cross pin and c clip to get the axle out?
I'm pretty sure that's how they were able to intsll the crosspin without grinding down the teeth. Since there's no C-clips, they probably put the whole carrier together (spider gears and all) on the bench, then dropped it all in and slid the axles in. Not very convenient for the next person who has to work on the thing though
So I'll be going to Ford tomorrow so they can rape me. Hopefully I won't run into any more problems. Money was tight enough already, now I'm missing work and shelling out $200 for this crap.
There are no C-clips on the front. Not sure exactly how it works, but I took the whole thing apart only to find that there are no C-clips. You can just unbolt the tube from the axleshaft and from the differential, then unplug the vaccuum lines and pull the tube off. There's some random crap holding the short axle shaft inside that tube. I think it was just a small c-clip or something. Remove the axle from the inside of the tube and you can access the seal.
