Replace entire powertrain 2000 F150 4x4
Just got given a 2000 F150 4x4 with a shot transmission. Truck has over 220,000 miles, but everything works perfectly except the transmission, and the body is cherry. Figured since I have no costs in yet, and was going to have the transmission changed, I"d change the whole powertrain. Found a salvage 2000 Expedition with only 52,000 miles and same 4.7 L Triton. Is this a simple swap?
Originally Posted by torkum
It will be simple if your truck has a 4.6 also. If your truck has a 5.4 some ECM changes will have to be made but no big deal. I would go for it.
on
The Expedition Transfer case is an All wheel drive transfer case. Your F-150 is not. Do not use the Expedition T-case. You may also discover that the Expedition has an 4R100 transmission, your F-150 has a 4R70W transmission. When did your retired factory trained Ford mechanic retire?
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
