3.73's with 35's question
got an 04 lariat 4x4 with stock 3.73 limited slip front and rear, im bout to put a leveling kit with 35's on and i tow a boat about an hour or 2 to the lake every 2 weeks or so during the summer and with the trailer it weighs roughly about 3,800lbs(give or take a couple hundred). will i need to get new gears? keep in mind i drive like a grandma because fuel economy is important to me but i also want power...... help!
i have 35's and 3.73
for the last 2 days i have pulled my 4wheeler trailer its a 13 x 5 maybe 4
w/ my polaris 500 ho .... web has it listed at 800 lb and im guessin the trailer
is 3 or 400 and my truck dont even know its back there....
i know thats alot off of the 4k your talkin about maybe someone can
get closer to your weight
Originally Posted by 2004Lariat5.4
but correction on that weight, my boat and trailer weigh bout 3500 to be exact
You'll be alright IMO. I'm running 35's right now on a 3.73 LS... I hauled some pretty heavy trailerloads of stuff out of my dad's house this winter. You won't be the fastest thing on the road, but you'll have enough power to pull it without a problem.
If you're towing every 2 weeks, that's not enough to justify the cost of new gears in my mind. if anything, pick up a Tuner like the EDGE that comes with the Tow setting. It'll help with the lost power.
well my mind changed very quick yesterday, i worked on a 05 f150 with 35's and he had the stock gears (3.73's) with no chip and it ran not much different than mine. you can tell there is a lil bit of weight to the tires but overall performance wise im pretty content with the 3.73's. ive been told by many mechanics that them 3.73's are some tough gears and the lil bit of weight i pull wont effect it enough to change any gears out. only difference will be in gas mileage, but nothin a lil cold air and a tuner wont fix. really appreciate yalls input by the way. hows that edge by the way.
IMHO...having driven both...a stock truuck with 35 inch tires and 4.56 gears is *significantly* more pleasing to drive than a stock truck with aftermarket intake, exhaust, progrramer & 35s & 3.73 gears. This is my opinion, so take it for what it's worth.
Torque multiplication is a wonderful thing.
Want even more power?
Put a programmer on top of all this.
And correct your speedo (because of the 35's & gears) at the same time.
