Using an 8.8 traction loc up front?
Old 08-06-2008, 05:07 PM
Code's Avatar
Originally Posted by Klitch
code, you need to double check the year ranges for the axle spline counts. i think pre 94 was 28 spl. dont quote me on it but i think its a strong possibility
Like I said, found that info on www.therangerstation.com can't vouch for it's accuracy.
Old 08-06-2008, 08:33 PM
RayD's Avatar
TRS is usually dead on but the only 31 spline Ranger 8.8s were in the FX4/FX4 level 2 trucks with the Torsen diff and all of those had 4.10 r&p. And pre-95 Explorers had 28 spline 8.8s. Anyhooo...I think this horse is dead.
Old 08-06-2008, 10:02 PM
Code's Avatar
I have a 93 8.8 out of an explorer sitting in my garage. It's 31 spline. Biggest difference between pre 95 explorer 8.8's and post is disk brakes
Old 08-07-2008, 04:09 AM
Klitch's Avatar
so it may be a ranger axle only then. hell i dunno now im confused.
Old 08-07-2008, 01:02 PM
Code's Avatar
HAHA ME TOO!
Old 08-07-2008, 01:59 PM
Klitch's Avatar
well i know ranger and exploder axles actually are different width too.
Old 08-07-2008, 07:54 PM
RayD's Avatar
Hmmm...I don't think that's the norm but I could be wrong. Wouldn't be the first time...
Old 08-08-2008, 12:19 PM
Code's Avatar
In an explorer it is the norm. I'm building a 93 explorer with a 79 d44/9" 5.13's spooled rear, locked front etc etc. I've spend a lot of time cuddled up in tech pages. They used the 31 spline in the explorer's because of the extra weight of the vehicle compared to the ranger. Good axles, planning on using my old in a hot rod one of these days.
Old 11-11-2008, 06:58 PM
JHL's Avatar
JHL
JHL is offline
Exclamation
YOU ARE ALL MISSING THE FACT THAT THE FRONT WHEELS WOULD BE SPINNING BACKWARDS WITH THE REAR GEARS OUTTA THAT MUSTANG...
The front gears on our 4x4s are reverse cut gears!
Originally Posted by The Saint
Hello;
I was surfing Craigslist and noticed an 8.8 Traction loc out of a mustang and thought hmmmm, would that work in the front differential of my 02 FX4?!?!
Has any attempted this? Or is there a 'no brainer' reason that it wont work?
If not, I was looking at Detroit EZ locker. Anyone have input on using these? My truck is used mainly on the street, but occasionally in the mud.
I would appreciate any input.
Old 11-11-2008, 08:37 PM
Code's Avatar
"Reverse Cut" is a misnomer. The gears do not turn in an oposite direction. It only refers to the cut of the teeth on the gears. The drive shaft turns the same way with either reverse or standard cut gears. High pinion axles run "reverse cut" and low pinion have standard.
All he is referring to is running a rear 8.8 carrier in the front 8.8. Aside from spline count it would work if setup correctly with proper gears for the f150.
Good info:
http://katy.tx4wd.org/tech/general_a...0Standard-Cut:
Old 11-11-2008, 11:35 PM
Klitch's Avatar
you both missed eachothers barn...... sorta...
JHL, nobody said to grab the complete diff with R&P and slap it up front. shouldnt assume that.
Code, are the mustang 8.8's 31 spl and the rangers 28spl? pending on year?
Quick Reply: Using an 8.8 traction loc up front?
