Why can't I find a gasket for my differential???
You can only use 75W90 in a Dana EX80. From the Amsoil application chart (1997 F-150 5.4):
Differential, Front .....GL-5
All Temps......80W-90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Standard Differential, Rear Dana Axle EX 80.....GL-5
Severe Gear 75W-90
Controlled Slip Differential, Rear Dana Axle EX 80.....GL-5*[2]
Severe Gear 75W-90
Controlled Slip Differential, Rear Ford & Dana 80.....GL-5*[2][3]
All Temps......75W-140
Severe Gear 75W-140
Standard Differential, Rear Ford & Dana 80.....GL-5[3]
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Notes:
[2] CS IDENTIFICATION: Letter & number on plate on door lock
pillar. (Models W/ Traction-Lok Rear Axle Add 4 oz of
friction modifier part no. C8AZ-19B546A (EST-M2C118-A)
[3] Synthetic oil is required.
Don't ask me how to tell whether you have a EX80, 80, or Ford rear, sorry. I'm not that smart.
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-140
Severe Gear 75W-140
Notes:
