CV axles on a 2003 f150
Old 05-05-2009 | 08:28 PM
rednutbow's Avatar
I tore the inner boots on my truck, so instead of paying 34-40$ for the boot kit i thought i would just pay the extra $30 each side, and get all new axles from advanced auto parts. (my truck has 73000 miles anyway) I noticed when i put the new axles in when the truck was up on the jack still, that the wheel would not turn because of the axles binding up! (stock ones did not) has anyone else had this problem? or has anyone put different brand axles in with no problem?
thanks David.
Old 05-05-2009 | 08:32 PM
minimonster17's Avatar
reman cv joints are garbage. you should have repacked the oem ones with grease, and put a new boot on.
Old 05-05-2009 | 08:35 PM
rednutbow's Avatar
they are not remans... they are new GSP axles.
Old 05-05-2009 | 08:56 PM
think of it this way, the oem cv axles cost $280 for a reason. aftermarket units typically contain weaker cages, and fewer ball bearings.
Old 05-05-2009 | 09:00 PM
rednutbow's Avatar
i just went to the ford dealer in Huntsville, Texas and they were wanting to charge me $400 per axle!
Old 05-05-2009 | 09:06 PM
try going to http://www.bobutterfordparts.com
they are located in TX, and sell brand new oem parts at wholesale.
otherwise, i would rebuild your oem axles. i rebuilt both of mine when the boots tore, its messy but not too bad.
Old 05-05-2009 | 09:11 PM
rednutbow's Avatar
yeah they are $281 an axle! i dont want to just throw a new boot on a axle that has 73000 miles...
Old 05-05-2009 | 09:14 PM
while the axle physically turns in 2WD, power is only applied in 4WD. your oem axles are much stronger than the ones you bought. about the only ones you could get that would be stronger would be custom-built ones.
Old 05-05-2009 | 09:23 PM
rednutbow's Avatar
well i also ran them for a while after the boots were torn. i would just feel better if they were replaced.
Old 05-06-2009 | 02:00 PM
Your replacement axles are either defective or the wrong ones for the vehicle. A quality reman should work okay.
Old 05-07-2009 | 02:04 PM
JMC's Avatar
JMC
If the cage in the joint is put in backwards at the factory it will cause binding. I returned 2 axles before I gave up and rebuilt my Ford one.
Old 05-07-2009 | 04:44 PM
rednutbow's Avatar
i got some remans from orielly auto, and they work perfect! if you know someone who is going to buy cv's tell them not to buy GSP pieces of crap!!!!
