Royal Purple Differential Gear Oil
I have used Lucas Oil Products in all my vehicles. Just sold my 97 F-150 which had 270,000 miles on it. Never used oil between oil changes, never had a problem with differentials except a rusted out rear cover. I always put the modifier in, just because. I guess it is personal preference on which oil you use, but I would have to say they are all pretty good.
Ok,
Who has used royal purple in their differentials ?? Have you had good luck with it? And did you use the Ford limited slip additive with it???
Royal Purple says that you don`t need to add any limited slip additive , because they added it at the factory. What is right??
Add or Not to add??
Lariat#1
Add or Not to add??
Lariat#1
see info at http://www.royalpurple.com/company-history/
ROYAL PURPLE HAS A FRICTION MODIFIER NEVER ADD ANYTHING ELSE EVER !!!!
Max Gear – High Performance Gear Oil
Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe
Max Gear is an ultra-tough, high performance automotive gear oil designed to provide maximum protection to heavily loaded gears while maximizing power throughout the drive train. Max Gear outperforms ordinary gear oils by combining the highest quality synthetic oils with Royal Purple’s proprietary Synerlec additive technology. Max Gear makes gears run smoother, quieter, cooler and longer without overhauls. Max Gear is formulated with a friction modifier additive – no additional additives are necessary.
Max Gear is available in the following viscosities: 75W-90, 75W-140, 80W-90, 85W-140 and SAE 90
Royal Purple API-licensed Motor Oil
Royal Purple’s API-licensed Motor Oil combines premium base oils with proprietary additive technologies to create high performance motor oils that optimize engine performance. Royal Purple’s API-licensed motor oil delivers superior protection and improves performance in gasoline and diesel engines. Royal Purple’s API-licensed SN motor oil meets ILSAC GF-5 and Dexos1™* performance requirements.
No special procedures are necessary when upgrading to Royal Purple. Royal Purple recommends waiting until the manufacturer’s first scheduled oil change in new gasoline and diesel engines before upgrading to Royal Purple.
Royal Purple motor oil is compatible with synthetic and conventional motor oils. Available viscosities include: 0W-20, 0W-40, 5W-20, 5W-30, 5W-40, 10W-30, 10W-40, 15W-40 and 20W-50 weights. Royal Purple also offers mono-grade motor oils in SAE 30, SAE 40 and SAE 50 weights.
