4x4 help
4x4 help
hello this is my first thread and i wanted to ask a question about my 4 wheel drive. I have a 2005 ford f150 xlt 4x4 with a 4.6l motor. I just bought the truck with 134000 miles on it. Every time i put it in 4 wheel low it is real delayed like i have to give it 3/4 gas before anything happens, then it jerks you a little and goes. 4 wheel high is a little delayed but not as bad. If you have any idea on what is wrong please let me know. Thanks
Have you had a shift 4x4 before?
The way it works is a pin is engaged into
the transfer case that locks the gears.
To activate the pin you need either
vacuum or electric. Since the hole that
lines up with the pin is spinning with the
front wheels there will be a delay in when the
pin falls into the hole.
Probably not a good idea to gunn it when you
shift but to take it slow until the pin engages.
Read this thread.....
The truck may have had a vacuum leak in the IWE system (maybe it has been fixed, maybe not). If it did have one, there's a chance your hub gears may be worn. Hopefully not.
Good Luck, MB
https://www.f150online.com/forums/ar...then-some.html
Good Luck, MB
