Confused!
Old 09-05-2009 | 09:47 PM
rjp's Avatar
rjp
Confused!
I have a 2003 F150 Screw. I am going to change the rear end gear oil. The owners manual says 75W 140, however the axle has a tag and a label that says use only FEHP 75W 90. What should I do? (Axle code 19)
What is FEHP 75W 90?
Old 09-06-2009 | 06:48 AM
kingfish51's Avatar
Use the 75w140. Ford changed their specs a couple of years ago to the 75w140. This is now their standard for the F150. And if you have a limited slip, do not forget the friction modifier.
Old 09-06-2009 | 06:58 AM
rjp's Avatar
rjp
Thanks. It has been in there for 6 years and 96,000 miles. Could it have caused any damage? It is not making any noise.
Old 09-06-2009 | 09:24 AM
kingfish51's Avatar
Should be fine. Rears are a fairly high mileage service unless in extreme service or water gets in.
Old 09-06-2009 | 12:24 PM
Axle code 19 is 3.55 without limited slip. Use 75W140 full synthetic.
Old 09-06-2009 | 10:24 PM
Roadie's Avatar
What engine do you have? If you have a 8.8 rear, the 75 W 90 may be the right lube.
Old 09-06-2009 | 11:16 PM
rjp's Avatar
rjp
Windsor 4.6
Old 09-12-2009 | 09:32 AM
Not on a 03 - all rears on those take 75W140.
Old 09-12-2009 | 01:52 PM
rjp's Avatar
rjp
I talked to guys at dealership and they said that 75W 90 should be replaced with 75W 140.
Quick Reply: Confused!
