Gear Ratio Question?
I purchased a 2006 SuperCrew f150 in 2007 used. Before I purchased it I researched the gear ratios as I was going to be lifting it 6 inches and adding 35" tires. The only thing I could find was that the 3.73 gears came in them. After I lifted my truck, I realized it was EXTREMELY Sluggish... I expected a little sluggish but not this bad. After looking at my tab on my pumpkin it said 3.55 gears. I was like WTF!!! I need to change theses out and do a lot of towing through mountains with my travel trailor. I also do a lot of freeway driving during the week. Should I go with 4.10 gears??? I just need more power in the mountains. Any suggestions?
If you came with the stock 245/65 R17 tires and 3.55 gears you were at 1750rpm at 60mph. Now with 35s you're probably closer to 1480rpm (I used 315/70 R17 =34.4").
4.10 gears would put you back to 1710 rpm; which would be good for DD and highway use
4.56 gears would up it to 1900 rpm. But it would be a lot better for towing. You may lose some mpg, but thats the price we pay for fun
if you have a 4.2-4.6L motor then you have a 8.8 rear end.
ALL IFS 97-09 front ends are 8.8r's make sure to get reverse cut gears
I know this is old, but what's a good company to get gears from? I was looking through 4wheelparts.com and found some 4.11's for like $180, but the reverse cut comes in 4.10? Is that a typo, or will that actually work? The manufactuer is G2.
http://www.4wheelparts.com/Drivetrai...5092&t_pl=2214
Randy's Ring and Pinion is pretty good and so is Richmond gears.
http://www.ringpinion.com/
http://www.richmondgear.com/
the front diff needs the 8.8 inch reverse cut. if you have a 5.4L motor, you need a 9.75" standard cut for the rear. if you have a 4.6L or 4.2L, you need a 8.8" standard cut rear. check out www.summitracing.com for some deals on gears. i hear yukon, precision and ford racing are good brands. i plan on getting ford racing when i do my swap. im not too sure about the 4.10 vs 4.11 thing.
if anyone else has some insight/ opinions on the subject, feel free to chime in.
