u joint symptoms
u joint symptoms
I think I have u joints going out. I hear quite a "squeak, squeak, squeak" when backing up, don't hear it in drive. Heard a wierd rapid clicking noise off and on yesterday, none today. I couldn't get the rear driveshaft to wiggle, but there may be a little play in the front.
What should I expect for a bill for u joint replacement?
If the squeak is proportional to the speed of the truck then, it does sound like U-joints. If you get a good mechanic who wont rip you off I would estimate a few hundred bucks. maybe $50 in parts, the job should take a reputable guy a couple hours and ~$75/hr. I would say $300 out the door just cause no matter what you do it will take them too long.
they are super easy to do by yourself, just make sure you dont drop a needle bearing down inside the cap when you install them.
Just youtube U joint replacement.
Depending on if you how many U joints you have, they are usually like 15-20 a piece and you will need two or three, and then a decent grease gun w/ grease
Sorry for a dumb question, but does my front driveshaft turn all the time? I'm assuming it does, so the front diff is where the infamous solenoids are at, or are they on the transfer case? I'm just trying to make sure my trouble-shooting is appropriate and accurate. What actually "kicks in" then when we go from 2wd to 4wd? Thanks, Jumpn
If your front driveshaft is turning all the time, then your diff is not being disengaged for whatever reason.
Your Cv Axles spin all the time the front shaft only spins in 4x4.. OMG dont ask me how I know (((( OK You Can ))) Had my ABS light on forever and ended up replacing axles and hub bearings .. One side I had to replace twice I got a faulty unit.. I also get the same squeak ( Low pitched when I back up ) I was thinking Maybe my back brakes.. I was told that warped rotors on the rear can cause noise and some vibration... But U Joints will cause a rumble and ticking sound... I bought a haynes manual and read the whole thing last week , I believe I would start by changing the U-Joints out , I have always used a big Clamp and a cheater pipe to with 2 pipe nipples to get mine out... I just hate to see people banging the crap out of a driveshaft it just doesn't seem right..
Finally got the job done last night. Working in single digits, but man it needed to be done. Rear u-joint was loose on the diff flange side, frozen on the driveshaft side. Used a press, got the caps off the yoke without too much hassle, but the the driveshaft ones were a pain!!!! Caps were kinked, pushed both sides numerous times, finally got it to fall apart enough to get it out. The u joint on the tranny side was fine, no play at all, so gonna leave well enough alone. Cost me a whole $18 dollars. By the way, it's a 12 pt 12mm bolts on the driveshaft for removal, just fyi.
