I read through the posts here and my problem is different! When I turn my 4X4 switch it doesn't light up and there is no sound at all coming from the front hub?
I checked both fuses and they are good!
Any suggestions would be appreciated..
Hmm... Well sometimes mine does not engage right away. I need to drive a lil bit for it to kick in. Have you tried that?
a common problem on these is the transfer case shift motor will go bad or freeze up and will bind and not work may need a new motor or your switch is bad and not commanding it for 4wd
tcase motor. shift motor... get it from rockauto, about $80... put it in, take the battery cable off for 30 mins, let the GEM reset, your back in business
