L/S to Spool?
L/S to Spool?
I have a 1997 F150 with the 5.4, auto tranny, 4wd, and the 3.55 8.8 rear with l/s. My clutch packs are shot and was wondering about upgrading my rear end while im back there. I have heard good things about spools (tough and provide more traction by locking the axles together), and have also heard bad things (hops around corners). Just curious what you guys have to say, seems like replacing the l/s with a spool would be a cheaper way to solve my problem and a little more traction couldnt hurt. But what is the difference between a spool and a mini spool? How hard are they to install? Would it really effect my daily driving ability that much?
First, I don't you have a 9.75 rearend? I thought all 5.4L came with the 9.75 Sterling?
Second, do not spool a daily driver!!! Tire wear and drivability (on road) will be horrible and you will break!... For a daily driver, a cheap "lunchbox" locker would be a much better choice.
![smoke](https://www.f150online.com/forums/images/smilies/smoke.gif)
I just installed a truetrac in my truck and I love it! As previously stated, It will never need rebuilding and it works better than clutch style l/s diffs. Just my 2 cents.
![beers](https://www.f150online.com/forums/images/smilies/beers.gif)
on
All 5.4 trucks got at the very least the 9.75 diff. All the 4.2 and 4.6 at the very least got the 8.8 diff. All the 250LDs and the later 7700# package trucks got the 10.25 regardless of the engine.
I also agree with the others. Do not spool a Daily Driver.
The cheapest option would be to rebuild your current differential.
