found traclok and lockrite for the 8.8 front end
Typically custom built CV shafts are expensive. Thats why nobody has come out with them. Most people wouldn't fork over the cash to buy them.
I'd love to get a set similar in design to a baja race truck, but you're looking at $1000 per shaft. But you'd be guaranteed you'd never have to buy another set again for the life of the truck.
on
powerlifter405,
See if you can get something for a 97-98 Lincoln MARK VII. The PN for the Lincoln and the front end of the F-150 are the same. FYI you will bust a CV joint long before you break the Diff. In the rear end the 8.8 should not be on a 4x4. Why does Ford use the 9.75 when you order a 5.4?
JMC
JMC
Originally posted by crusher
I'm not having a tough time with the shafts. But i am wondering
if the 31 spline diff innards would fit into the 8.8 IFS of an F-150?
Also, what about the hubs? Are there 31spline hubs that would work?
Anyone!
Anyone!
Can't swap the gears. The front is a reverse cut gear set and the rear is a standard cut. So no you can't swap them out.
Also there are no huybs on 97+ F150s. Theres a center axle disconnect just off the drivers side of the pig. The thing you have to find will be 31 spline axle shafts for an 8.8 IFS and good luck. They'd have to be custom made. In order to get 31 spline shafts you'd have to find a blank set of 8.8IFS shafts and have them splined to what you need. You need to find these shafts since you need the mounting flange on the end for the CVs to mount on.
There are hubs on the 150 it's just they are not the disconnecting
type. (More of a bearing and hub assembly)
What ever the axle shafts fit into on the front wheel
would also have to be 31 spline
No they're not any hubs on 97+ F150s. Its just a bearing assembly is all thats on the outters. No hub mechanism. All it is is a sealec bearing assembly with a splined center, and in some cases ABS sensors. I don't know how you could consider that a hub assembly.
