Worth it to take it into the dealership?
Hey guys,
Have a 2007 SCREW 4X4 thats just about ready to turn over 36k, and I had a couple nagging little issues I was going to take it into the dealership on, but now I am wondering if its just something to do myself and save the hassle of taking it in.
In the past 100 miles, the power steering pump started making a horrible whine/growl in the cold temps. I have read around about the same issue with other members, and could probably flush the fluid and replace with some full synthetic and maybe help it out.
Also, the other day it threw a fit and wouldn't move the gearshift out of Park (column shift). Hit the brakes, lever wont move, etc. Turned the truck off, put the key into the 2nd position, moved to Neutral, started fine, hasnt happened since.
Minor issues, yes. But, if they turn into major issues after the warranty, will I kick myself?
Ended up being worth it to take it in (thanks Big_Smokey). They are going to replace the PS Pump, and also found a leaking exhaust manifold, so they are going to fix that on their dime also. Not a bad day all and all.
They didnt find anything with the brake switch that controls the park interlock, but, I can deal with that if it happens again.
So, maximizing the warranty is a good thing after all.
