8.8?
8.8?
Me and a buddy of mine have been disargreeing on which rear end I have in my truck. Its a 97' with the 5.4, auto tranny, 4wd. I do know that it does have l/s (junk) and 3.55 gears. Im pretty sure it has the 8.8 but he thinks it has the a 9.75 or whatever it is. I am also curious about removing me junk l/s and adding a lock-right from powertrax. Its supposed to be much better off road, and stronger than l/s. Basically a locker except it unlocks around corners and when you let off the gas. good price too. also 28 or 31 spline axles?
Ditto..and an interesting fact
As for your topic, there is an LS for the 9.75 and you can buy a Detroit true track or Eaton for a pretty penny.
Couple of things. You probably won't find much at Jegs or Summit for the 9.75. Probably need to look at one of the gear/ axle companies.
Take a look at this site, and you can see the difference in shape betwen teh 8.8 and 9 3/4.
http://www.yourcovers.com/diffcover_9519.php
All cars in NASCAR run aftermarket versions of the Ford 9".
