Used parts? / Break in times?
if the shop says 300 without bearings, think again. bearings are a must.
I changed the gears in my 1969 SS 396 Chevelle back in the 70's from a 3.73 to 3.31 ratio. I bought used gears and changed them myself (1st time). I had been told by a mechanic that used gears will sing a little no matter how well they are set up and he recommended using new gears. When I finished, the gears did sing a little but not much. Many new rears make as much noise as it did. Back then, I only paid $25 for the used ring and pinion.
Those Chevelles were awesome in many ways. They weighed about 3600 lbs. and with that big block, they were so much fun to drive. My engine in my 69 wasn't in great shape so I was hesitant to push it so much, but earlier, my high school best friend had a 67 with the 350hp rated 396. He changed the cam to the 427 425hp cam with solid lifters and it would turn up 6600 rpm when wide open in 4th gear with a 3.55 rear gear, running about 155mph. Running 7"wide slicks (the only ones allowed in "stock" classes, it would turn 107mph in a quarter mile on the Kinston NC drag strip.
Let's don't talk about gas mileage!
