Diffy friction modifier
I just got my 06 shorty crew 4x4 back from being serviced today. One of the things I had them do was check the differential as I just noticed the rear end would stutter as I gave it gas turning right or left mostly from a stop or near stop. I have owned this truck for about 3 weeks and it is my first Ford. I read about the woes of not adding the modifier after changing the diffy oil from this site. They said the clutches looked good and a flush, new fluid and modifier would be all I would need. Well it still gives a rumble. not quite as bad but not like it was when I bought it. I basically picked up the truck from the shop and drove straight home. Does this modifier have to work in and loosen things up for a bit or do I have other issues?? The shop closed for the weekend as I left so I have to wait till monday to call. Any ideas???
Thanks!
Thanks!
Thanks for the input. I am quite sure they used whatever Ford recommends. They changed the plugs and I know they were going to use Motocraft and non other as they said " whatever Ford recommends". I will check in with them on Monday. I'll get some miles on her this weekend now that I know that it needs time.
GLC Thanks for the input so far. I will find out tommorrow on what they used. How much modifier should go in? I have been driving for about 120 kilometers mostly highway but drove around a bunch of shopping centers this morning. It is the worst when I back up, then turn left or right then drive forward. Thats when it almost shakes the truck. I can crank the wheel to the left or right and do a 360 with little or no vibration. It vibrates a bit from a stop then left or right only about 60% of the time but the worst is reverse, stop then forward withthe wheel turned. They said the clutches were ok. It doesnt vibrate when I go to reverse then back out of a parking stall. Have I gave it enough time to soak in? What else other than the diff could it be?.
on
1 Post
I have read the Ford friction modifier is the best. I have also seen guys running it in their Chebby's. In an 8.8 or 9.75 diff one bottle is all that is normally used if you have a stock cover but I have read that some who still have the shudder have added another to fix the problem. I have two in mine with my Mag-Hytech cover.
Hello!
Straight from the OWNERS manual - 4 oz of Motorcraft XL-3 in a 9.75" LS diff.
==>http://www.fcsdchemicalsandlubricant...ransaxle Fluid
Cheers!
MGD v4.1
Cheers!
MGD v4.1
