Rear End Locker
Rear End Locker
I got a 2005 F150 supercrew 4x4. I was wanting to put a locker in the rear end so both wheels spin. Do you guys have any recommendation or is this even possible. Any help would be greatly appreciated. I have 3.73 gears if this means anything. As u can see i'm kinda of clueless.
A typical stock "four wheel drive" truck with open differentials is really only two wheel drive (one front and one rear). An open (not locked or limited slip) differential will transmit power to the wheel with the LEAST traction. Most transfer cases don't have differentials so you get one driven front wheel and one driven rear wheel. A true four wheel drive will have a locked front and rear diff. If you want to go that route though, put a limited slip or manual locker in the front because a locked front diff won't allow you to turn much.
There are basically 3 types of locker for you to choose from.
1. Manual lockers
2. Automatic lockers
3. Limited slip (O.K., not technically a locker)
With the manual lockers you have a choice of air: http://www.arbusa.com/Products/Air-L...eering/11.aspx flip a switch, a solenoid sends air from a tank and engages the locker.
Electric: http://www.eaton.com/EatonCom/Produc...cker/index.htm flip a switch, an electromagnet engages the locker.
or manual: http://www.ox-usa.com/ox/Products/Lo...9/Default.aspx pull a lever and a cable engages the locker.
With an automatic locker, http://www.eaton.com/EatonCom/Produc...ials/index.htm, it "ratchets" going around a corner and locks when going straight. No action is required by the driver.
A limited slip differential will transfer torque to the non slipping wheel but doesn't lock them completely together. Besides the E-Locker, about all of the detroit's are limited slip http://www.eaton.com/EatonCom/Produc...ials/index.htm
After that, your budget will dictate what you will get.
Hope that helps.
1. Manual lockers
Hope that helps.
I don't think I have limited slip. I was stuck in the snow and my rear right wheel and front left wheel were the only ones spinning. I would like to make so that in 4 wheel drive I'll have both rear wheels and one front wheel spinning, and in 2 wheel drive both back wheels will spin, is this possible.
What is the door code for your axle. If it is 2 numbers, it is an open. If it is a letter and a number, it is limited slip. Just because only 2 spun, does not mean you do not have limited slip. It can be defeated.
If you do not do any hard core off-roading, you would be better off with limited slip over a locker.
It is B something, I just back upped and punched it and looked out my mirror, it looks like both wheels are spinning. So it must be limited slip. I just figured that both spinning at the same time would be better. Maybe what I really need is what mental was talking about and having both front wheels lock when needed.
Again, the front shouild really only be an open Locker or LS up front could cause problems steering in slippery conditions. The vehicle will have a tendency to go straight, no matter how the wheels are turned.
I would verify that the the LS rear is okay with no problems, and leave it at that. If you must, get a locker that can be manually locked, and use it only when going straight.
Unless you use your truck for off road alot, a front locker will not be of much use for you. Now a rear locker is nice to have, i would recommend a eaton e-locker...that are pretty good products.
Just to give you an ideal of how something will drive with front and rear lockers locked..my jeep has both front and rear lockers and it is nearly impossible to make a turn with both locked. when we take it offroad and climbing ridiculously steep hills is about the only time i use the front locker. I can't even make turns on the trails with the front locker locked. Most all the time im offroad i keep the rear locked and thats about it...So unless you do some serious offroading i wouldn't throw away a bunch of money at a front locker. A rear locker you may get a little bit more use out of...I would get one.
Problem with putting a locker on the rear, is the LS will have to be ripped out. Personally, I prefer the LS. I have a locker on my 09, and would prefer the LS as the locker on the 09, come into play in 4x4. LS is there at all times, for things like wet roads, etc. A locker, even in the rear only can really only be used in a straight line, unless you have really slippery conditions. The rears have to turn at 2 different speeds in a turn.
LS is anytime, and a replacement locker would be anytime. It is just the way the 09 up works in that it is only in 4x4. You would have to remember to engage the locker, assuming it is a manual engagement. Only problem with the automatic ones is they can be very noisy, as they ratchet when not engaged.
i'd go with a E-locker in both differentials and put switches right on the dash in a convient position. for the people that says having a front locker is going to make it impossible to steer and will pull your truck straight no matter how far your wheels are turned, god come on thats aggravatin to read it aint right. aint yall ever been muddin or drove on completely snowed roads or even loose grass/dirt after some rain??? when your in 2wd your being pushed and you can go straight when turned all the way if your front tires break traction. when your in 4x4 your being pushed from the rear tires but the front tires are PULLING you whichever direction they are turned. im gonna assume its understood that you'd never use a front locker on pavement or equivilant(you wouldnt need to anyways) because your outside tires have to spin faster than the inside ones and this would kill a locked diff. the only time you'd ever use your front locker is when you need extra traction, because you aint got no traction!! so imagine your in a mud hole now(or any other no traction situation), is it gonna matter if one wheels spinnin slightly faster than the other? hell no, its only going to help you when you have two wheels pulling you instead of one wheel pulling and one wheel draggin and counting against you...... im done rantin now and will simply say i'd recomend two high quality E-lockers that will fully lock when engaged but be as open as possible when disengaged, in BOTH differentials
