Welding up LSD.
but that locker in the rear still allows the separation of the axles to allow them to spin at 2 different speeds while going around a corner.
a true locker locks the two shafts together so they spin at the same time. it may just be my lack of knowledge on lockers but how would a locker allow them to spin at two different speeds?
They do...when power is applied. Once you let off the gas they would open back up. So unless you coast through the corner you would be locked.
Be easy on it if you have weight in the back. Just arch your corners and don't count on the tires to slip and you will be fine if you don't do something stupid with it.
Had a mud truck with welded fronts once and it would literally jump when turning lol. That thing would go through anything with the fronts welded though . Rears were welded on that thing for a couple of years with 0 issues. Had a 460 pushing around 500ish hp and broke shafts but who doesn't when they beat the crap outta it....
Jeff
Jeff
