new pinion bearing?
new pinion bearing?
Hey all, I have an 01 f150 8.8"diff and i am installing a new trac lok diff and ring and pinion. I have a set of test bearings(for the pinion shaft) i have used to set my pinion depth, backlash and carrier(diff) preload. After a few test builds i have a great looking paint pattern and everything else is good. But my problem is the new smaller pinion bearing will not slide onto the new pinion shaft(my stock one came right on and off by hand). So I am scared to put the bearing in and try to tighten the flange and pinion nut to press it on. Again i am talking about the smaller pinion bearing that meets the crush sleeve. that installs from the driveshaft flange side of the diff housing. Again simply my problem is installing my new smaller pinion bearing onto my new pinion(Not the press fit one by the pinion head). Anyone that has been here or has any suggestions, let me know, i appreciate it.
Hey Ram Air, thanks for the hint, i actually did the same thing with the bearing races, i will freeze the bearing before i go to install sometime this week, hopefully i will not damage the threads on the pinion pressing that new bearing on by installing the driveshaft flange and nut, but i think it will work out fine. I will post the outcome later on.
wait you said that the bearing is too small for the pinnion shaft right? well freezing it will only make it smaller as ram air said it will contract it. you either need to press it on or you can throw it in the oven and let it heat up to 200 . only leave it in there for a little bit and use an oven mitt to get it out. if the bearing is too small you need to expand it I.E. HEAT. if a press is not available. the oven trick will work though thats what i did and mine worked like a charm and no problems!
