how do i know if my 4x4 is working 97f150
Old 09-25-2010, 03:21 PM
kingdumb's Avatar
Question how do i know if my 4x4 is working 97f150
hi i have a 97 f150 when i turn the **** on dash nothing happens???? how can i get this to work?? should i replace ****?? should i change a fuse? if so what fuse idk what to do
Old 09-25-2010, 05:29 PM
glc is offline
The owner's manual has a complete fuse chart. If you don't have it you can download it.
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 09-25-2010, 08:13 PM
Oneill230's Avatar
Normally with mine you har a clicking noise and then a second one. The first one is the electrical, and the second is the 4wd engaging. Pretty much just look it over on the manuel. Out of all the things on my truck thats the one thing i hate (i have a 97 also) is a **** for the 4x4. I wish it was one of those floor shifters cause they dont depend on electricity to use it.
Old 09-25-2010, 08:42 PM
str8t six's Avatar
welcome to the forum!
probably just a fuse. a light will come on in the guage cluster when it is in 4wd
Old 09-28-2010, 06:24 PM
kingdumb's Avatar
ok so whats next?
i checked fuses and they are fine. what about the ****/switch is that what i should check next?
Old 09-29-2010, 09:11 AM
Hawk2010's Avatar
Could be corrosion on the gem module connection. Could be a bad gem. I had the same thing on my 97. It turned out to be the gem.
Old 09-29-2010, 10:14 AM
str8t six's Avatar
check the vacuum lines that go to the front differentail for cracks or leaks
Old 09-29-2010, 10:24 AM
Hawk2010's Avatar
Check for voltage at transfer case motor connector. If voltage detected, motor or tranfer problem. If no voltage gem or speed sensor problem. That is if you hear no clicking when flipping switch to 4hi or 4low.
Old 09-29-2010, 05:40 PM
kingdumb's Avatar
yea no clicking at all
Old 10-01-2010, 02:42 PM
Hawk2010's Avatar
Is anything else not working right. Interior lights working like they should, auto window down working. I know it sounds funny, but the gem module controls these things. Ford had a problem with the gem. I have a 97 also, replaced gem 6 months ago. I finally took it to the dealer and had them put on the computer. I had a short circut in the vss circut. New gem and it is working fine.
Old 10-03-2010, 06:37 PM
kingdumb's Avatar
everything else works other than my tailgate haha i cant get it to open
Old 10-03-2010, 06:42 PM
03fordcrew's Avatar
Does the 4x4 indicator light come on in the dash?
Old 10-04-2010, 08:10 PM
kingdumb's Avatar
yea it comes on when i turn truck on but not when i turn ****
Old 10-05-2010, 04:54 PM
kingdumb's Avatar
so where can i veiw how the vacuum hose runs?
Old 10-05-2010, 07:38 PM
03fordcrew's Avatar
My shift fork in the front diff that engages the 4x4 broke on my truck. Dealer replaced it under warranty. Difference is that my light came on in my cluster. The truck still thought it was in 4x4 even when it wasn't. I would turn the **** and the light came on, but no clunk sound of the front diff engaging.
Quick Reply: how do i know if my 4x4 is working 97f150
