Any one running a Truetrac 913a477 in 04+ trucks??
Something isn't right there.....you shouldn't be wearing tires and you shouldn't hear it grab at all...mine doesn't.....you might want to call EATON and talk to them..something isn't right. What are you using for fluid in the rear?/
Isn't the true track a tor-sen design.
That is the best for all rounder if you ask me. Normal driving like and open diff, only if torque difference (like one tier is slipping) it start working. so it shouldn't wear the tiers. and thy are maintenance free only Chang the oil every now and then, and Liv for ever. thy should be quiet i have driven a few cares withe tor-sin diffs non mad any nose or felt any engagement. it is transparent.
How does adding a Tru-Trac or other locker affect the traction control on the newer F-150s? Is there some reprogramming needed, or will the computer automatically adjust to the new paradigm of going from open differential to limited slip or fully locked?
I've been reading through the many posts about limited slip differentials, lockers, and such, but haven't come across that item yet.
